Fuel Prob. on D15 II
Henry P
04-08-2007 19:21:52
I can run tractor for about 20 min. after that the fuel in the filter runs out and motor quits. I have replaced filter and found the fuel will not flow unless I loosen the line to the carb. This is a gravity flow system. I have checked the float and needle in the carb., both working fine. Any Ideas?
dbloyd
04-11-2007 08:25:47
 Re: Fuel Prob. on D15 II in reply to Henry P, 04-08-2007 19:21:52
my model c did the same thing. it uses a vented
cap and mine was stopped up, so i drilled an extra hole in it and made it a little bigger. problem solved.
Dave Anderson
04-10-2007 16:12:08
If the problem is not solved after the cap is loosened, try removing the fuel bowl, line to carb, and unscrew the rest of the fuel bowl from the tank. See if the fuel flows freely when you do this, as sometimes floating crap can be sucked down into the nipple, temporarily blocking the flow. Bumble bees and red clover heads are a couple of things I have found floating in a gas tank!
Texas Denny
04-08-2007 19:31:22
Try loosening the gas cap. I had the same problem with my D-14. I just set the cap of the tank instead of screwing it down and all works fine. The tractor probably requires a vented cap which had been replaced by a non vented cap. Someday, I will drill a small hole in the middle of the cap to solve the problem forever. Mine usually worked good on a full tank but failed a 1/4 tank or less.
Henry P
04-08-2007 19:41:36
 Re: Fuel Prob. on D15 II in reply to Texas Denny, 04-08-2007 19:31:22
Will try that this weekend. I just put gas in it and only put about 5-6 gallons.(thats about 1/4 tank) Thanks.
