temp guage
geogas
04-07-2007 13:26:43
how hard is it to install a temp guage on allis b 1950s model? Mine is broken and i have found some on the internet. It has been broken ever since i owned tractor(10years). I didn't want to get in to any thing where i could break the old one and coolant is going everywhere. Thanks
old
04-07-2007 15:46:50
 Re: temp guage in reply to geogas, 04-07-2007 13:26:43
Most of the time there easy to remove and install. I have never had any problems on any of my Allis tractors. Shoot you don't even need to remove the hood to change it
Texas Denny
04-07-2007 15:43:31
It usually isn't hard to remove. Occasionally, it can be so tight that you could break the water neck getting it off. I'd suggest using a hacksaw to cut off the big part of the gauge. Make sure you retain the hex potion for the wrench. Then put a 6 point socket on that hex and try it. If it doesn't come out easily, soak it for a few days with a penetrant like mystic or WD-40. Then try to tap the wrench with a hammer first in the loosen direction and then in the tighten direction. If it doesn't come, a few more applications of penetrant are in order.
Don't worry too much. Those water necks are available on Ebay most of the time. You would need to remove some anti-freeze to remove the neck and maybe a little even to remove the gauge.
