D14 Brake drums
Jeff Duensing
04-06-2007 20:14:23
How do you get this off the axles? I am about ready to cut them off so I can get to the pinion bearings.
Thanks,
Jeff
baldwin
04-09-2007 13:17:56
 Re: D14 Brake drums in reply to Jeff Duensing, 04-06-2007 20:14:23
BFH is the only way got to just keep beating on them until they come off I did that on mine last year and even a puller doesnt work got to beat them off
Gatz
04-07-2007 18:51:52
Jeff, some heat and possibly a puller.
Be careful using a puller tho'....the drums can break off.
And don't overheat; as the axle may get too hot.
When re-installing, make sure the drum is fully seated on the round ring.
Heat may be necessary for installing too.
Have a piece of pipe and a sledge ready in case you need to drive it home.
