D-17 belt housing mounted hyd. pump.
vwnjr
04-06-2007 05:38:08
I'm looking for the shift and hardwear needed to mount the hyd.pump of a Series IV onto a Series III. I want true live hyd. for the loader I'm putting on. Thanks for any and all help.
vwnjr
04-07-2007 06:07:17
 Re: D-17 belt housing mounted hyd. pump. in reply to vwnjr, 04-06-2007 05:38:08
Thanks, BobHnwOh. Didn't know about the one and two shaft thing.
Mounting on front is the very last place I was wanting to put it. 1, it looks all cobbled up no matter well you try to make it look good. 2, it makes it much harder to put weights back on when the loader is taken off for mowing, raking, need weights, 3 point rake, yes the front tires are loaded. Thanks anyway. May put it on front after all.
JMS/MN
04-07-2007 14:51:24
 Re: D-17 belt housing mounted hyd. pump. in reply to vwnjr, 04-07-2007 06:07:17
I believe the two shaft thing is this- inner one goes to the tranny, outer one runs with the engine and drives the hyd pump. Factory had available a front mount pump- doesn't look cobbled together. That's why the front crank pulley is drilled and tapped for the bracket and shaft to the pump that sits in front of the radiator. Want to carry front weight?- run 3 or 4 inch channel iron forward along the side frames, make a square frame in front to hold rocks, weights, chains, etc. Add a front hitch for backing wagons, etc. Very handy.
BobHnwOh
04-06-2007 15:42:59
Don"t think it will work,lV uses double shaft lll uses single shaft.
Joe(TX)
04-06-2007 05:49:09
Have you considered a front mounted pump? It would be easier.
