D17 Lif Problem
Ron Nickels
04-05-2007 21:24:47
I recently bought a D17. It was leaking oil around the lift arm shafts. I tore it down and the cylinder in the rear end had a bad seal. I replaced the seal and now the lift does not work very well. Appears to have air. Do I need to bleed it, if so, How do I do that?
Ron Nickels
04-06-2007 18:01:44
 Re: D17 Lif Problem in reply to Ron Nickels, 04-05-2007 21:24:47
Thanks for the reply. I have it working now. Actually I did not have it full of oil.
JMS/MN
04-06-2007 07:46:38
Needs to be cycled a number of times to bleed out the air. If you have a mounted implement to hang on it, do that, otherwise push the arms down manually each time you raise them with the pump.
