hydraulic cylinders
terry palmer
04-05-2007 16:49:19
Not haveing any luck finding cylinders for my wd45. In the new nothern catalog p.549 they have the lion 3000 psi cross tube cylinder. Will this work? Or is there a some place else I should be looking? Will I need to adapt this some way?
GENE IN
04-07-2007 07:56:55
 Re: hydraulic cylinders in reply to terry palmer, 04-05-2007 16:49:19
go to allischalmers and ask on discussion page.
it will not let me say .com
Terry palmer
04-06-2007 12:45:08
OK folks let's dumb this down for me. What should I be looking for in psi if these don't handle the pressure? Is there a specific brand, model # I should look for. I don't want to get the wrong one too weak, just wrong. Thanks for the help.
Joe(TX)
04-06-2007 05:54:34
Like was stated before, you can use the lower pressure cylinders as long as you are careful about bottoming them out. Use a larger diameter cylinder. The pressure will only be what it takes to move the cylinder until you hit the end. Then it goes to whatever the pump is capable of.
Check Surplus Center. They have more choices.
Texas Denny
04-05-2007 19:41:02
They are available on Ebay almost all the time. It is best to use Allis cylinders because the system is high pressure where as cylinders from most manufacturers are not rated high enough.
terry palmer
04-06-2007 16:57:41
 Re: hydraulic cylinders in reply to Texas Denny, 04-05-2007 19:41:02
Not up on E-bay. What site should I look for?
Thanks Terry
chalmersbob
04-06-2007 19:18:11
 Re: hydraulic cylinders in reply to terry palmer, 04-06-2007 16:57:41
allis chalmers site or hydralics site on ebay. also try tractor junk yards, used parts suppliers.
Bob
