Timing WC
WCJoe
04-04-2007 18:56:35
I need advice on timing a 1942 WC with an electric start, coil, and distributor. I loosened the bolts hold the distributor housing and rotated it slightly as the engine was running. It runs OK but is still out of time. Any advice?
WCJoe
04-06-2007 14:32:31
 Re: Timing WC in reply to WCJoe, 04-04-2007 18:56:35
Thanks for the responses running great.
hillbillyOH
04-06-2007 04:57:02
Check the order of the plug wires, too.
gene (missouri)
04-05-2007 09:03:55
I use a timing light or static time my WC.
Jerry Coulter
04-04-2007 19:23:43
If you can find an electronic tach to attach to the primary lead on the coil, with engine running, disconnect 3 plug wires, have someone hold the governor to carb rod in wide open position, turn distributor until RPMs peak. Then retard it very slightly and it will be really close.
