Need to know name of a part
RobJJ
04-04-2007 18:02:48
On the piece (I've heard it called a "quadrant") that the throttle rod, and hydaulic rod ride along, it appears that the hydraulic rod and the throttle rod ride along the quadrant on small pieces that appear to attach to, and move along, the quadrant rails. My quadrant is broken (I've bought a good one off ebay) and the two small pieces are missing. Can anyone tell me how the two small pieces work. Obviously the rods go thru them, but how do they attach to the quadrant? Or do they actually attach to the quadrant? Are these generic parts, or specific to the ACs? As things stand, I have to hold the throttle rod as as soon as I release it, it goes back to idle...I'm hoping those two piecs will hold the throttle (or hydaulic) rods at the position they are released.
Rob
stu (ON)
04-05-2007 11:29:24
 Re: Need to know name of a part in reply to RobJJ, 04-04-2007 18:02:48
The friction blocks are notched to ride along the curve of the quadrant. On the opposite side of the quadrant there should be springs on each rod to keep the friction blocks pressed against the quadrant. If these are rusted off (quite possible) then you have to go down the rod and disassemble at the first connection to allow you to slide new springs up the rods.
stu
Ted in NE OH
04-04-2007 18:32:50
They are called FRICTION BLOCKS and go on the throtle rod and hydraulic levers. They keep the levers from moving when you don't want them to. Your AC dealer and many aftermarket suppliers have them.
