New to AC (just bought a WD45)...well, new to tractors in general. Never owned one, never driven one, just always liked them, and since it is a mechanical thing, had to have one. It will be a working tractor one of these days. A couple of questions...I'm sure more will follow.What are dos/don'ts about using the hand crank. Good idea/bad idea. I've heard, that with cars, that how you do it is everything. Do it wrong, you can get hurt...do it right, just good exercise. Is this the same for tractors? I know a lot of guys with 6-volt cars, switch to 8 volt batteries. I've heard this is not too big a differnce to create problems, such as bulbs burning out from getting too hot. Is this the same with tractors? The one I bought, needs a new battery/perhaps starter, or perhaps just some resetting the grounds. It pull starts very nicely, but either the battery is dead, or the starter, or ??? I figure if I have to get a new battery, before I do, thought I'd get ideas as to if the 8-volt substitution is/isn't a good idea. The hydraulics work ok, but there is a leak somewere as the bar will slowly drop under weight. Where might the problem be? Is whatever might be the problem, repairable/rebuildable? What is the availablility of parts (new, used, repops) for the WD-45s? Only thing I noticed missing, is the battery box (tray is there), some type of protection to prevent rain from entering the exhaust stack. What is the purpose of the pulley on the right side (doesn't seem to be a driven pulley, but rather an idler pulley...what would it have been used for. Ok, that's enough for now...donchathink. Thanks, Rob
