Miners wick for model b
Ribeng
04-01-2007 08:29:50
The crankshaft of my model B should have a "Miners wick" for clutch spigot bearing lubrication. Mine is missing and I cant fine any specifications for this. Can anyone help please?
Brett Phillips
04-03-2007 10:11:59
 Re: Miners wick for model b in reply to Ribeng, 04-01-2007 08:29:50
The wicking is actually a piece of 1/2" diameter hard white felt. According to my service manual, it should protrude 1/8" from the end of the hole in the crank toward the pilot bearing. On the inside it should be trimmed flush with the crank throw. The manual says to push it in, but that is something like trying to push a rope uphill while keeping it straight. I have had good luck with tying wire around the end and pulling them through from the inside.
ribeng
04-03-2007 23:23:35
 Re: Miners wick for model b in reply to Brett Phillips, 04-03-2007 10:11:59
Thanks for that Brett
ribeng
04-03-2007 07:41:37
Thanks for that. Please do you know any more info on this. Like how far out of the crankshaft should it protrude either end. Is it rolled lengthways and how tight should it be packed? Also please could you give a contact email or web address for Agco. Agco in UK say they dont cover Allis Chalmers.
Thanks
Toby(NC)
04-01-2007 12:10:01
The wick is available at AGCO.
ribeng
04-01-2007 23:16:41
 Re: Miners wick for model b in reply to Toby(NC), 04-01-2007 12:10:01
Thanks for that
