170 diesel head gasket
mike hipp
03-29-2007 12:54:43
I think I have lost the head gasket in my 170 diesel. Is there anything special that I should do or look for during the replacement? It appears that I have to take the rocker arm assembly off to get to the last few head bolts??
torque needed for head bolts?
torque for rocker arm?
any advice?
thanks mike
jadpro
03-30-2007 14:11:41
 Re: 170 diesel head gasket in reply to mike hipp, 03-29-2007 12:54:43
I would suggest buying a shop manual. It can answer most of you questions.
indiana ac man
03-29-2007 19:22:02
hello mike i belive your 170 diesel has the perkins 236 in it if it is like mine it has head studs not bolts and it can make the head a bear to remove some of the studs froze to the head so we had a real fun time we finally backed the studs out and replaced the gasket it torqued at 85 pounds but i dont remember the sequence for the studs
Gatz
04-01-2007 10:48:36
 Re: 170 diesel head gasket in reply to indiana ac man, 03-29-2007 19:22:02
Torque specs and sequence info from I&Ts AC-201 Shop Manual.
third party image
Note that the following spec is for Diesel only....
third party image
