1947 AC
Mick S
03-28-2007 18:12:34
Hi all, new to this area, going to look at a 47 B 12 volt system with PTO & a bush hog attachment. Man says not running, thinks points are bad & dead battery. I"m looking for something to use on 5 acres to just mow & grade driveway & maybe pull a few stumps & logs. Will this unit do it? I appreciate any and all help here, any web sites with info on what to look for. Also, can you add a loader to this unit & what is approximate cost if known.
Again, thanks to all in advance, just not mechanically talented !!! Dangerous with tools.
old
03-28-2007 18:36:39
 Re: 1947 AC in reply to Mick S, 03-28-2007 18:12:34
Well a B is around 22HP and is a good little tractor but it has its limits. Stumps unless small forget it . Now for mowing and some other things there good but if it doesn't have a 3 point gradeing a road with it will not be easy to do.
Mick S
03-28-2007 18:47:35
 Re: 1947 AC in reply to old, 03-28-2007 18:36:39
Thanks for the quick reponse, he is asking 900 for it as is. Any known problems I could look for? The guy seems pretty straight forward, in no hurry to sell. Also will it take a front end loader or too much $$ to convert?
Thanks again, Mick
old
03-28-2007 19:03:12
 Re: 1947 AC in reply to Mick S, 03-28-2007 18:47:35
If it has good tires on it and the sheet metal is good 900 isn't to bad if it runs or can be made to run easy. Yes they made a loader for them but again its a small tractor and is limited as to what it will pick up. I own a couple Cs which are almost the same as a B and I use them all the time, but as I said limited to what they can do. I tried to pull a farmall M today with oe of my Cs and all it would do was spin. I had the power but not the traction that I needed.Shoot when I tried to jerk it I broke the chain which could have been bad if it had back lashed and hit me. Theres a picture or 2 of my C in the web page
