I need help Allis B and Woods 59
Chad from Michi
03-27-2007 03:49:20
Hi everyone!
Last night I drove to buy a 1938 Allis B crank start only but it does have the Hyd pump on it.
Then I left there and drove to where I bought a Woods L59-AC mower.
The woods Mower has all the mounting hardware because I had it mounted up, (missing the front spacers to bolt in front of draw bar)
The right side of the tractor has the lifting portion of the woods mower but it didn't have the hand lift. It had a pivot for it by the way it looked there was a bolt in it but no handle.
What I am looking for is some pictures of a woods mower deck lifting mechanism. Or some possible picutres of one hooked up to a allis hyd cylinder.
Or can I buy a culivator hand lift and use that along with the mower?
anyone with pictures or some help? Maybe I can get the lifting parts from woods?
Chad
Jerry Coulter
03-27-2007 10:42:35
 Re: I need help Allis B and Woods 59 in reply to Chad from Michigan, 03-27-2007 03:49:20
I don't believe a cultivator lift would be satisfactory since it works a cross-shaft mounted behind the seat. If no lift lever is present, you must have a hydraulic type lift system. If you e-mail your snail-mail address to me, I would sent you photo copies of my material which should help.
Chad from Michigan
03-28-2007 03:13:57
 Re: I need help Allis B and Woods 59 in reply to Jerry Coulter, 03-27-2007 10:42:35
Jerry
Thanks for the help! I think I am keeping the Hyd's on the tractor and I found the cylinder for the tractor.
I also went to the woods website and printed off the manual for the mower so I am all set!
Thanks for the offer!
chad
