Allis C starter
casefrank
03-26-2007 17:23:19
I have a 44"C" and want to put a 12V starter in. Any ideas Can I use a newer B,C 12V starter?
Thanks
Frank
cranksum
03-28-2007 11:07:26
 Re: Allis C starter in reply to casefrank, 03-26-2007 17:23:19
I have been using my B that has a 6 volt starter with a 12 volt battery for 7 years now. No problems at all.
JMS/MN
03-26-2007 22:33:58
They all came with a 6V starter. No such thing as a 'newer 12V B,C, starter'. If you want to convert to 12V system, use the same starter. No need to switch. They simply turn faster, which helps starting. Conversion to 12V would be an alternator and 12V battery, ignition system, etc.
old
03-26-2007 21:05:35
6 volt or 12 volt for the most part there the same. So if you have a 6 volt one use it and don't waste your $$ on a 12 volt one till the 6 volt one goes bad which by the way wil be years from now. I do a lot of 12 volt conversations and I always use the 6 volt starters and most have been on them for decades and still keep working just fine
russ1
03-26-2007 18:01:42
You would need to count the teeth on the replacement to make sure it will work. If you are converting to 12volts your 6 volt starter will work fine. I have done that on 3 vehicles recently and they start really well on 12 volts. If you want to go ahead with 12 volts you can also have your starter rebuilt for 12 volts.
CENTAUR
03-26-2007 17:41:34
Do you have a 6volt starter? If you do you already have what you need.They start faster and will give less trouble then they would useing 6volt battery. CENTAUR
