AC 200
chad 72
03-25-2007 12:58:33
My 200 has a leak around the front injector looks like oil but I have relaced the valve cover gasket it looks like it is coming from around the little piece of rubber around the injector but hrad to tell getting pretty bad any common fixes?
Hurst
03-27-2007 17:32:58
 Re: AC 200 in reply to chad 72, 03-25-2007 12:58:33
Also, diesel can get black and look like motor oil by picking up dirt as it flows. I would check the return lines, those things can leak sometimes.
Hurst
856puller
03-27-2007 08:14:36
it could be the bleed off line on top of the injector injection line or a bad copper washer on bottem of the injector
Joe(TX)
03-26-2007 18:20:57
All that seal does is to keep dirt etc out of the injector hole.
