C or CA implements
scott d. TX
03-22-2007 06:40:49
I am looking for implements/attachments for a C, what is the difference in CA equipment?
scott d. TX
03-23-2007 10:06:09
 Re: C or CA implements in reply to scott d. TX, 03-22-2007 06:40:49
If a "B" has the same engine will its front cultivator fit?
85_Ranger4x4
03-23-2007 10:38:32
 Re: C or CA implements in reply to scott d. TX, 03-23-2007 10:06:09
It should mount up if the B had a C narrow front axle, the B had a one row cultivator in the middle as opposed to the two row the C used.
Eldon (WA)
03-22-2007 21:04:12
From what I can see, no mounted equipment (other than maybe a #3 mower) will fit both a C and CA...CA has a different hydraulic lift system and the front end is a couple of inches longer.
JMS/MN
03-22-2007 08:33:15
The difference is in how they mount to the tractor. Example- front row-crop cultivator on a C mounts to a square bar that bolts under/behind the radiator. CA uses bolt holes in front of the radiator.
