Spin Out Wheels
hdlong
03-21-2007 07:31:21
How to repair or rebuild clamps for Spin out rim one side loose and moves in and out 2-3" the locks are about 2" away both side of clamp when centered
Gene IN
03-28-2007 08:45:53
 Re: Spin Out Wheels in reply to hdlong, 03-21-2007 07:31:21
weld up the back of the eccentric block and ground it so it is thicker than before. It will let the eccentric bolt tighten up more and it will not slip on the rail.
Sarah from Tulsa
03-24-2007 19:02:37
You can't just rebuilt cast steel. It is much easier to rebuild the metal rails and machine to spec.
Ted in NE OH
03-21-2007 14:12:47
I woild weld up the friction blocks and machine smooth. Welding rails is a lot of work and then the rim won't slide easily on the rails when you want it to.
JMS/MN
03-21-2007 13:52:14
You're likely to find wear on the rails as well as on the eccentric bolts that push against the rails. You'll have to dismount the tires to weld up the rails. The clamps are meant more to act as a stop when moving the wheels- the friction between the bolt and rail is what holds it in place. Once they wear enough to slip- they need to be built up to new.
