WD wheels
tracy redd
03-19-2007 19:28:51
I bought 2 WD last week. One is in good shape and the other is rought shape but runs ok. I am using rough one for parts. One has good wheels and other one has bad wheels and mismatch, I am trying swap the wheels. I loosen all 8 lugs and wheel won't come off. I spray WD-40 around it and i work it for a hour. no luck. The wheel is not rusty. I don't have a sledgehammer. i am going to have somebody help me and borrow the sledgehammer tomorrow.
Any advice for this?
Thanks
Tracy
NE IA Dave
03-19-2007 22:51:07
 Re: WD wheels in reply to tracy redd, 03-19-2007 19:28:51
If non of the other simple methods work, loosen bolts as old suggested. Drive another tractor close / side by side and chain the wheels togther. A single chain around both wheels is all you need. Avoid doing it near the valve stem. Then have both tractors drive away from each other at a slight angle. Yes you can get into trouble if both drivers don't pay attention, but it most definatly will pull them loose.
Texas Denny
03-19-2007 20:38:04
I just read Olds reply. I like his plan because it is so much easier and safer. I'd try his approach first. If it doesn't work, them use the hammer.
Texas Denny
03-19-2007 20:35:27
They may come off hard. A heavy hammer may be required. Be careful with the hammer that you don't damage the rim or the wheel center. Probably the best place to hit is on the wheel center. If you can, hold a heavy bar on the wheel center edge and hit the bar instead of the wheel center. Hit a bit on one position and the rotate the wheel and hit 180 degrees form your first strikes. Then go 90 degrees and then 180 then 90 then 180, etc. In this way you get the wheel from all four sides and kind of rock the wheel off.
old
03-19-2007 20:31:43
Simple way to pop them loose is put the nuts back on but leave them loose, about a 1/16 of and inch from the rim. Then start it up and drive it around in a figure 8. Listen close and you will probably here when they pop loose. Be sure to stay close to where your tools are because once they pop loose you don't want to drive it very far.
