WD 45...What year is it?
JB in KC
03-18-2007 19:41:47
I just bought a WD 45, and I'm not sure what year it is. Does it matter for buying parts? Where is a good place to find a serial number?
Thanks, JB
old
03-18-2007 19:49:07
 Re: WD 45...What year is it? in reply to JB in KC, 03-18-2007 19:41:47
Serial number is on the left rear axle houseing just under the brake plate. Theres a flat spot there with it. Now then are you sure its a WD45 not a WD since if you don't know what to look at they will look the same?? A WD will have a bolt on side plate on the right side of the engine and a stright shifter and a WD 45 will not have that plate and the shifter will have a little curve in the shifter. And yes know those thing can make a differance in what parts you need
chalmersbob
03-19-2007 18:47:32
 Re: WD 45...What year is it? in reply to old, 03-18-2007 19:49:07
late model wd had the curved shifter also.
the side plate and the engine serial # are the best way to tell what you have. engine serial # will start with 45 if its a wd45, with wd if its a wd. Bob
John in KC
03-18-2007 20:00:42
Yes it has the curved shifter and no plate.
Thanks for the info.
JB
old
03-18-2007 21:31:01
 Re: WD 45...What year is it? in reply to John in KC, 03-18-2007 20:00:42
Then its a WD45 seen a good number of WDs sold as WD45 and thats a shame to see a person fouled in that way
John in KC
03-19-2007 06:01:53
 Re: WD 45...What year is it? in reply to old, 03-18-2007 21:31:01
How can I tell what year it was made?
JB
old
03-19-2007 07:28:43
 Re: WD 45...What year is it? in reply to John in KC, 03-19-2007 06:01:53
Well as Texas say just find where your number fits into the list of serail numbers.
Texas Denny
03-19-2007 06:38:19
If you now have the serial number, go to "Research & Info" on the left of this page and click on "Serial Numbers", then "Allis" and then "WD-45".
