WD45 engine wows
dave westlund
03-17-2007 18:09:02
I have a WD 45 that smokes like a chimney. Before I tear the engine down. What should my compression be? And I would appreciate any comments or help you can offer.
Thanks Dave
old
03-17-2007 19:07:10
 Re: WD45 engine wows in reply to dave westlund, 03-17-2007 18:09:02
Anything over 100psi is good but the higher the better. 100 psi is about as low as one will go and still run ok but I have seen lower and still do ok. Your problem could be bad valve seals/guides, sticking rings or a few other things. One way to check if its sticking rings is put about a 1/4-1/2 cup of tranny fluid in each cylinder and let it sit a couple days. Then start it up and see if its smokeing less
dave westlund
03-18-2007 04:20:15
 Re: WD45 engine wows in reply to old, 03-17-2007 19:07:10
Hi Old,
Thanks for your reply.
