D15 Series 2
Jim Black
03-14-2007 15:52:16
I bought the above tractor at a farm auction, and the tractor slipped in the clutch unless idled down and the speed gradually restored thought the problem was in the power director.Bought some hole gages and attempted to adjust the Director by removing from the outside and moving to the center, with no luck.I can start the tractor, engage the power director in either high or low range now, no pto, no arm lift.Do I have the power director improperly adjusted, or do I have the main clutch out?The clutch peddle feels like the preasure plate is good.I have maintained the overall dimension for the power director body, anyone have any suggestions?Thanks
Butch(OH)
03-14-2007 18:35:46
 Re: D15 Series 2 in reply to Jim Black, 03-14-2007 15:52:16
Yup the foot clutch is out as neither the PTO or hydraulics runs through the PD clutches.
JMS/MN
03-14-2007 17:18:09
Can you shift the tractor into gear with the foot clutch, or are you shifting with the PD? Pto and hyd are powered after the foot clutch, before the Power Director. Sounds like you're not getting power through the foot clutch.
Jim Black
03-15-2007 03:48:02
 Re: D15 Series 2 in reply to JMS/MN, 03-14-2007 17:18:09
JMS I am shifting the tractor in gear by depressing the foot clutch, and then engaging the power director into either the high or low position.The tractor has an hydralic loader on it, ands it function correctly.The hydralic arms on the rear do not move when engaged nor does the pto turn.Thanks for your reply
JMS/MN
03-15-2007 08:21:43
 Re: D15 Series 2 in reply to Jim Black, 03-15-2007 03:48:02
The loader on the tractor- does it get hyd from a separate pump driven directly off the engine? That would explain why it works, but I still think you have foot clutch problems. Are you moving the transmission shift lever when depressing the foot clutch, or is it already in a gear and you stop motion with the PD?
Jim Black
03-15-2007 14:27:41
 Re: D15 Series 2 in reply to JMS/MN, 03-15-2007 08:21:43
JMS, I am depressing the foot pedal, shifting the transmission in gear and the engageing the power director.I also think that its the main clutch, just hopeing that I am missing something.
