MODEL B TIMING
Rick Pratt
03-12-2007 12:38:01
Van some one explain how to set up the timing ? Also, where is the timoing mark located ? Have had the mag partially off. Now need to set up initial timing.
Thanks,
Rick In NJ
Clay in MI
03-12-2007 19:10:18
 Re: MODEL B TIMING in reply to Rick Pratt, 03-12-2007 12:38:01
Rod (NH)explains it as well as anybody. By the way - Thank you Rod if you're out there!
Rick Pratt
03-13-2007 14:52:09
 Re: MODEL B TIMING in reply to Clay in MI, 03-12-2007 19:10:18
You guys are good !!!!! worked well. Took the mag cap off one more time and tweeked the points and used the procedure you guys sent for the meshing of the 2 gears, set up the plug wires properly, and BAMM. S.O.B. started on the 1st crank of the starter. thanks again. without guys like you, people like me would be junking stuff.
ps. Had no oil pres. took of the oil pan and screen was worse than ANYTHING I ever saw. Will put that back tomorrow.
old
03-12-2007 14:39:27
Send me an e-mail and I will send you a manual for the mag that should explain how to do that
