One-Sixty Hyd Check
Farmboy46
03-11-2007 10:07:12
When I bought my One-Sixty, it did'nt come with a manual, so I'm fumbling through some stuff. Does the transmission and the hydraulics have the same sump? If so, where do I check the level and add more fluid if I have to. Thanks to all.
PAUL BAXTER
03-15-2007 06:28:02
 Re: One-Sixty Hyd Check in reply to Farmboy46, 03-11-2007 10:07:12
Yes, the hydraulic system uses the transmission sump as its source. You check the level by a plug on the side of the transmission housing. Make sure the tractor is parked on a level surface and remove the plug, if the lube level is up to the plug it is full. By the way, the proper fluid is 10w-30 motor oil.
