Allis WD head
Tracy Redd
03-11-2007 09:22:45
How many foot pound of torque to tighten the head on the block? Can the head can be shave? I was told that i can't becasue the piston will hit the valves.
Thanks
Tracy
Harry J. Case
03-12-2007 20:46:21
 Re: Allis WD head in reply to Tracy Redd, 03-11-2007 09:22:45
Hey Tracey Listen to these guys, they know their onions, if you try to mill one of these heads you are going to be getting into the valve seats, mill the block or go for higher compression pistons. Good luck, Harry
Texas Denny
03-11-2007 16:15:13
Aaron is correct. You would need to plane the block. Better plan is new pistons with a higher compression ratio. For instance, you may find some after market pistons for LP.
ag-lad
03-11-2007 11:56:22
90 ft/lbs; 25 ft/lbs on 3/8" studs.
Aaron SEIA
03-11-2007 10:20:46
Shaving the head is pointless, it's flat, the combustion chamber is in the block. Can't remember the torque.
Aaron SEIA
