AC-B horse power
Stonewall
03-10-2007 12:27:07
Hi fellas. I've mounted a 12kw generator on the back of my b allis chalmers, now my question is does anyone have and idea what the actual horsepower is on the motor, and the PTO shaft? My books tell me the engine is 125 cu. inch, the belt h.p is 22.3 and the drawbar h.p is 19.5. This generator has a 6.6 or a 7-1 gearbox on it as close as I can tell, and it is suppose to turn the generator at 3600 RPM. the book says the B has a PTO speed of 560 @1400. What do you folks use to check motor speed? I realize this is to large a generator for this tractor, the rule of thumb that I've got from other sites is 2 PTO h.p per 1KW, but you will get out what power you put in proportinly. That why I'm wondering what a B's PTO horsepower really is. Sorry to be so long winded here, hopefully someone can help me. Thanks
steve(ill)
03-10-2007 19:34:42
 Re: AC-B horse power in reply to Stonewall, 03-10-2007 12:27:07
that gear box will heop a lot. you need to know the generator RPM or the frequency output. just get a meter on the output end. what you realy need is 60 cycle current which is normally 3600 RPM.
jwal10
03-10-2007 15:38:01
Belt and pto is the same,engine horsepower is right off back of engine, pto or belt is after clutch and shaft, drawbar is power to the ground.
