D17 gear oil
CliffordPaul
03-08-2007 05:54:03
I've had an oldtimer tell me just to run straight 30 weight motor oil in the transmission/real end and that the hydraulics run on either 10 or 20 weight oil (I can't remember which) as opposed to what I would instinctively put in which is hytran fluid. Any comments?
Thanks
MT in Walford
03-08-2007 15:04:58
 Re: D17 gear oil in reply to CliffordPaul, 03-08-2007 05:54:03
Transmission-
My WC owners manual says to use SAE 140 gear lubricant for temps above 32 degrees and SAE 90 for colder times when the temp is 32 or colder. I think this is pretty standard.
Differental is the same.
Hydraulic fluid I believe should be used in the hydraulics.
Mike in Iowa
