WD45 coughs and stumbles
Jeremy Conaway
03-06-2007 23:49:51
I own two WD45"s; a "55 and a "57 which are my first tractors. The narrow-front "57 was my first one and has been mine for about a year now. It"s not the prettiest-looking but isn"t too bad though it has its share of fluid leaks and could use a paint job. The "55 came to my house a few months ago because it has a wide-front, is much nicer-looking, has better hydraulics and 3-point system and has a fully hydraulic front loader.
Both have power steering and have also been converted to a 12-volt alternator system.
The "57 starts at a mere tug of the starter, literally taking about 1 second to start in either cold weather or warm. It runs smoothly, requires very little choking and is immediately drivable with no choking or bogging down. It"s a real joy to drive. It"ll spin a 6 foot bush hog without complaint, too.
The "55 is a different story. It takes 2 to 5 seconds to start it unless the engine is warm, is much more picky about the choke position and wants to cough and sputter a bit when starting out from a standstill unless you slip the clutch quite a bit. Once it"s warmed up it"s better, but it"s still not as cooperative as the "57. It does have fresh spark plugs installed.
The "57 is up for sale because there"s only room for one of these machines in our budget at the current time. I really have mixed feelings about selling it because it runs SO well, but the "55 is in so much better shape and has much more to offer so it seems to be the smart choice. If it would just run as well as the other I would have no regrets selling the "57.
My question is, does this sound like a carburetion issue? Carbs are not exactly my favorite thing to adjust so I"m hoping someone can give me some pointers. Where should I start with it, or is there something else that I"m missing?
Any help would be greatly appreciated.
Thanks!
fence row
03-24-2007 19:47:11
 Re: WD45 coughs and stumbles in reply to Jeremy Conaway, 03-06-2007 23:49:51
yep champion no good toss them away, ac45 plugs are good ones to use. my wd carb had water in it and it ran bad , might need cleaned out.
Jeremy Conaway
03-07-2007 09:00:13
Haha, that's ok.
Thanks again for the info. It may be a couple days before I can mess with it much, unfortunately. Your comment about temperature is well taken, it's just that the 57 has been so awesome about starting in all temps without the "stutter" that I expect the 55 to act the same way. I'm hoping that this issue can be resolved and not that the it's simply a harder-starting tractor, especially since here in IL it can get quite cold at times.
Bill(Wis)
03-07-2007 20:26:43
 Re: WD45 coughs and stumbles in reply to Jeremy Conaway, 03-07-2007 09:00:13
If it's a WD-45 it'll have a distrbuter type ignition system (no magneto). Might be a bad condensor. Have you checked color of spark? Should be bright bluish white. If it's orange, you've got a problem, probably the condensor. Also, if it has champion spark plugs, I'd throw them out and get autolite. Personal opinion on spark plugs.
Butch(OH)
03-07-2007 05:01:14
There are two reasons the 55 would act like that, one common, one not. The uncommon one would be a weak ignition. Warm motors fire easier, less pressure in the cylinders fires easier. A weak ignition could cause harder starts and a miss or studder when accepting a poad. I include this only because of the slight chance it isn't the probable cause which is a lean condition. Lean could be from also be from several things. vacuam leaks from bad gaskets or cracked manifold, dirt in the carburetor or could be simply miss adjusted. Id bet in missadjusted. There are two adjustments on the carb, idle (up top) air jet and main (at the bottom) jet. Turning the idle jet in will enrichen the mix at idle and just off of idle. Turning the main jet out will enrichen from idle upwards in RPM and load. Remember the idle jet is controlling air and the main is controlling fuel thus adjustment proceed ure for rich is opposite. With the tractor idling and warm turn the idle jet out until the motor sounds worse then in until at best (your only talking a turn each way here or you have other problems) Once idle is set then go to the main jet, open jet (out) untill the engine will accelerate without stumble. Sometimes this will cause a very slight black smoke but will give best power. A lot of smoke is too rich and will be hard on plugs and less power. Dont get carried away screwing jets in and out as your not very far off or it would not run as good as it does, maybe half turns at most.
Jeremy Conaway
03-07-2007 05:56:45
 Re: WD45 coughs and stumbles in reply to Butch(OH), 03-07-2007 05:01:14
Thanks for the quick helpful reply, Butch. If I remember correctly the idle jet has a little "L" shaped doohickey that you turn. Are you basically saying to screw it out until it sounds rougher, then screw it back in until it smooths out and then some more until it sounds rougher, then back it off half the distance between the two? It may be tomorrow evening before I get the chance to look at it, but hopefully the main jet is simply out of whack. If we can get this tractor to run as well as the "57 I"d be thrilled to death. In the mean time, I need to stop and pick up a new battery. The "57"s battery was dead so the one in the "55 got drafted for duty since a guy is coming to possibly buy the "57 after I get home from work tonight. From reading this forum apparently it takes a group 25 battery so hopefully the kids at the local auto parts store have a clue. I was going to measure the battery box this morning before leaving for work but ended up getting a late start and didn"t have time.
Butch(OH)
03-07-2007 08:37:22
 Re: WD45 coughs and stumbles in reply to Jeremy Conaway, 03-07-2007 05:56:45
Good gawd I proof read my first post twice and it still looks like a 2 year old wrote it, sorry. Yes you have the adjustment proceedure close enough, just dont adjust it with a cold motor, some cough or studder is normal with a cold motor. The top notch tractor tuners (read cheapskates for buying fuel, LOL)used to tune for the season and weather. Richer for colder or more load, leaner for less load and hotter.
