WD45 Rear Wheel Rail Stop Clamp won't fit.
MikeRW
03-06-2007 14:03:52
I have a WD45. On the rear right wheel i have a Rail stop clamp installed on each side of the eccentric on the rail that has holes in it. On the left side i was one rail stop clamp short and recently purchased one. when i went to install it on the rail as like i have it on the right side, it wouldn't fit. There wasn't enough room between the holes on the rail so that the eccentric and a clamp on each side would fit. Anyone know what's up with that. The clamps all appear to be the same size. i have the rail stop clamp installed with the head of the bolt on the outside. This doesn't seem like brain surgery. Either the wholes are too close, or i have them installed wrong, or there is more than 1 size of rail clamp. Any ideas. Please help. You guys are gonna come up with a simple answer and i'm gonna feel dumb and have to drink.
Thanks, Mike.
Butch(OH)
03-07-2007 05:03:38
 Re: WD45 Rear Wheel Rail Stop Clamp won't fit. in reply to MikeRW, 03-06-2007 14:03:52
There was also a batch or reproductions around that were drilled wrong. Seen them for sale at shows.
Eldon (WA)
03-06-2007 18:56:17
Ya got the wrong stop if it doesn't look like the others...there were a number of different styles. 38" wheels were different I know....Just use one on the side that the wheel pulls against and you will be ok. I haven't seen very many tractors with two on them.....normally the tractor won't have enough traction in reverse to slide them.
JMS/MN
03-06-2007 14:58:02
First thing I would do is whang the wheel tight against the original wheel stop- then try to fit the 'new' one. Who made the new one? Originals should fit. Once you're sure the wheel is tight against the original stop, I'd just grind off the new one until it fits. Might be made too wide, only takes a few thousandths of an inch.
