Rear Main seal leaking on a WD
Branden
03-06-2007 09:28:13
I put a complete gasket set on my WD, and now when the tractor is running, oil leaks quite a bit out of the back of the motor. It doesn't leak when the tractor isn't running. Any ideas?
ccrock
03-07-2007 06:07:19
 Re: Rear Main seal leaking on a WD in reply to Branden, 03-06-2007 09:28:13
Did you soak your two piece rear main seal in oil before installing it? And do you have shims under the bearing cap?
JMS/MN
03-06-2007 15:04:00
Oil leaking down onto the cover plate in front of the clutch? Go back a page or two-three, regarding how to install oil pan gaskets. Never cut off the thick short ones that go on the curve, overlap the side ones properly, over the curved. Also good idea about putting shellac/sealant on only the pan side.
Branden
03-07-2007 06:57:19
 Re: Rear Main seal leaking on a WD in reply to JMS/MN, 03-06-2007 15:04:00
I didn't soak the rear main seals in oil when i installed them, i'll give that a try this weekend. Thanks for the tips!
