WD, narrow to wide front, difficult?
flinny
03-06-2007 02:33:18
OK, my third post in a row. All about my WD.
How difficult is it to 1) find a wide front for a WD 2) and install it?
Anyone been through the process?
thanks
Brad W Wi
03-06-2007 05:11:08
 Re: WD, narrow to wide front, difficult? in reply to flinny, 03-06-2007 02:33:18
Been there, done it. There are wide front ends for sale on here from time to time or just ask. As far as changing it out no problem. The wheels fit both and all you have to do is disconnect the steering and remove the bolts holding the front end on. I had to loosen up one of the frame rails to get the narrow front off and to slide the wide end on. Total time was 1.5 hours give or take.
flinny
03-07-2007 02:06:50
 Re: WD, narrow to wide front, difficult? in reply to Brad W Wi, 03-06-2007 05:11:08
Thanks Brad,
I see you are from Wisc, so am i. SouthWestern.
Do you know where I can pick up a wide front end close by (upper midwest).
Best, flinny
A/C Boy
03-06-2007 05:35:51
Is it possible to change a WC narrow front to a wide front end? Did the WC come in a wide front end? Good question Flinny.
Eldon (WA)
03-06-2007 06:38:44
 Re: WD, narrow to wide front, difficult? in reply to A/C Boy, 03-06-2007 05:35:51
Late model WC used the same 3 bolt wide front as the WD. Early WC wide front is underslung and getting hard to find. Email me for a pic of it.
