b or c dished rear wheels?
boberg
03-05-2007 14:59:06
what is the difference?????
steve(ill)
03-06-2007 15:12:43
 Re: b or c dished rear wheels? in reply to boberg, 03-05-2007 14:59:06
bob- there were two ways to put the cast hub onto the axle shaft. the original B had a 2 inch diameter axle shaft with big tapered splines on it. you pushed teh cas hub onto the splines, then install a big hex nut on the outside and tighten it dwon to pull the hub tight on the taper. later the c came out and the splines were eliminated and a plate with 5 bolts made onto the axle shaft. now the cast hub was installed just like an automotive wheel. the B continued to use the splines on 90% of the tractors. if you bought an adjustable front axle tractor, they put the 5 stud axle shaft on that tractor.--- the C hub was a deep dish and the B hub was a shallow dish. the guys said at a later date the B used the C hub, i dont know, that may be true. All of the wheels (rims) installed with 4 "locks" on the outer edge of the hub that camlock to the rim. This is after 1940. the original 1938-39 had a couple other "first year" modifications in this area. cant be sure what you have.
Dakota Dave
03-05-2007 19:18:46
The C dished Wheel Part # 210214 was also used on adjustable Frount B"s after serial #B18055
acsteve
03-05-2007 18:02:14
I have a B with the C styled dished wheels. I think they came on Bs which had adj wfe.
steve(ill)
03-05-2007 16:18:30
here is a photo of a B hub
http://www.tractorshed.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.tractorshed.com/gallery/tphotos/a100499.jpg&firstrec=32&lastrec=47&Parameter=allis&mode=All&what=tphotos
steve(ill)
03-05-2007 16:15:08
here is a young man on a C, note the deep dish.
http://www.tractorshed.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.tractorshed.com/gallery/tphotos/a101391.jpg&firstrec=1&lastrec=15&Parameter=allis&mode=All&what=tphotos
steve(ill)
03-05-2007 16:05:49
the B only has an inch or two dish, the C is several inches deep. same bolt pattern.---- most B did not have the bolted hub. Most had the splined axle shaft design.
boberg
03-05-2007 16:15:35
 Re: b or c dished rear wheels? in reply to steve(ill), 03-05-2007 16:05:49
by bolted hub do you mean 4 adjustment bolts or center bolt
LWD
03-06-2007 04:36:03
 Re: b or c dished rear wheels? in reply to boberg, 03-05-2007 16:15:35
I have a `B` narrow rear end with the five stud axel ( not a hole lot of them around)
