I am using my WD block and plan on using the WD45 crank and pistons. How do I know which pistons to get as I heard 45's had both flat-top and dished? I think I want/need the dished pistons? Are there different comp. ratio pistons for the 45 and which do I want?ANSWER(s) Same block(basicaly) so you need WD-45 pistons for a WD-45 crank. Just get the pistons for a WD-45 as sold in many places and websites. They will be the correct compression ratio for gasoline. There used to be differant ratios for differant fuels but I bleieve all you can get now is gasoline ratios which will work in a pinch for LP but not for distillate. Can I use my same rods? I don't know the wrist pin diam. for the 45 pistons. ANSWER, Rods and pins are the same for both engines. 4" or 4 1/8" cylinder liners? ANSWER, About all you will find is 4 1/8" nowadays without lots of searching. Just get a WD-45 liner and piston kit and save yourself some gray hairs, searching and mix and matching. Can I use my WD Zenith carb, or do I need the 45 carb? ANSWER, The WD-45 carb and air cleaner is differant. The WD stuff should work OK but HP will be a tad less.
