J4B3 Magneto
DavidKittle
02-28-2007 16:50:38
Hello;
I need help with the setup and timing of a J4B3 magneto in my 1951 Model B.
Appreciate any help.
Thanks
Rod (NH)
02-28-2007 17:04:30
 Re: J4B3 Magneto in reply to DavidKittle, 02-28-2007 16:50:38
Hi David,
Try this.
third party image Rod
DavidKittle
03-01-2007 18:12:03
 Re: J4B3 Magneto in reply to Rod (NH), 02-28-2007 17:04:30
Hello;
I have a 1951 model B with a distributor on it now. I want to put a magneto on it. Do I need to buy or change anything in the governor, or not?
Thanks
Rod (NH)
03-02-2007 08:32:22
 Re: J4B3 Magneto in reply to DavidKittle, 03-01-2007 18:12:03
David,
Assuming your tractor is factory-original in that area, I don't think you would have a problem in swapping the distributor with a magneto. According to the parts book, the same governor drive gear was used for both mag and battery ignition tractors up to tractor serial number B123996, which would be mid-year 1953. However, since parts can be interchanged over many years of the B and C, you will have to check visually to be sure. If you remove the distributor assembly and it has the two drive tangs like a magneto, you should be good to go. If, on the other hand the distributor is driven by a gear extension from the governor drive gear, then the governor drive gear will have to be changed out with one that has the drive tang recesses for driving a magneto.
Rod
