Source for ally nuts?
Tom Cumming
02-27-2007 10:15:22
I'm rebuilding my, "B"'s engine, and I'm looking for an online source for the alloy engine nuts and sheet metal kep nuts. Anybody know a source?
Thx, tom.c
A/C Boy
03-01-2007 06:11:11
 Re: Source for ally nuts? in reply to Tom Cumming, 02-27-2007 10:15:22
Get then from Prairie Implements (DARCY) 218-338- 6156. That where I got mine . I had to replace one rod and needed the nuts for the rod caps. They were 46 cent each.
Gatz
02-27-2007 11:34:32
If you can't find them locally,
try McMasterCarr.
They have alloy & Kep nuts and are usually competitive when it comes to smaller quantities.
Just type in the search box when the site comes up
Tom Cumming
02-27-2007 12:01:59
 Re: Source for ally nuts? in reply to Gatz, 02-27-2007 11:34:32
Thanks for the McMasterCarr link, I forgot all about them. I guess what I need to know now is the ANSI/ASME specs. In particular I'm looking for the nuts that hold the piston rod to the crank.
They also didn't seem to have the sheet metal kepnuts. I hate to use something that doesn't match the original. I suspect there's a reason they used that particular design.
thx, tom.c
chalmersbob
02-27-2007 17:31:44
 Re: Source for ally nuts? in reply to Tom Cumming, 02-27-2007 12:01:59
I'm sorry, but what is a kepnut? Bob
Gatz
02-28-2007 09:44:47
 Re: Source for ally nuts? in reply to chalmersbob, 02-27-2007 17:31:44
typical for Kep nuts
Tom Cumming
02-28-2007 22:58:02
 Re: Source for kep nuts in reply to Gatz, 02-28-2007 09:44:47
Well, not exactly. Those may be kep nuts, but what I'm referring to is a second nut that's tightened up to the first to keep it from turning. Usually the kep nut (that I'm referring too) is thinner than the main nut.
In my, "B"'s case, it's a thin sheet metal, "nut" like thing. I don't want to reuse them because they're so flimsy, but I don't want to put something on there like another nut because that may make it go out of balance or something.
I suspect they designed it to use these nuts, so I don't want to use something else... unless you guys know better!
Thx, tom
t
03-01-2007 03:56:13
 Re: Source for kep nuts in reply to Tom Cumming, 02-28-2007 22:58:02
I think what you are looking for can be found if you search for "palnut" actually I think what your after is referred to as a hexlock palnut.
McMaster Carr Should have them.
Gatz
03-01-2007 08:24:39
 Re: Source for kep nuts in reply to t, 03-01-2007 03:56:13
Ah, OK...shoulda realized you were working on the engine.
As Tom said, those are called "Pal Nuts" or "Speed Nuts" and McMaster does have them.
Tom Cumming
03-02-2007 15:45:26
 Re: Source for kep nuts in reply to Gatz, 03-01-2007 08:24:39
Those are them! I was calling them the wrong thing!
Thanx!!!
tom
