D-19 hydrau;ic
mixman
02-27-2007 08:30:19
My D-19 pump comes and goes. You can here it when it is working. I have had the pump rebuilt changed filter cleaned everything as well as can be. Any suggestions?
Tom Cumming
02-27-2007 10:10:23
 Re: D-19 hydrau;ic in reply to mixman, 02-27-2007 08:30:19
Does the hydraulic fluid have air in it (frothy)? If it's sucking air you can hear it when it cavitates.
tom.c
mixman
02-28-2007 11:19:34
 Re: D-19 hydrau;ic in reply to Tom Cumming, 02-27-2007 10:10:23
It has been awhile since I had this apart. Where would it be sucking air and if so why does it work great sometimes and not others?
Tom Cumming
03-02-2007 16:02:35
 Re: D-19 hydrau;ic in reply to mixman, 02-28-2007 11:19:34
I don't know where it would be sucking air from, I just know how hydraulic systems work, and that's the symptoms. The reason it's intermittent is that it doesn't need much of an opening, and that opening could get intermittently plugged so it works, or the opening could be right above the level of the fluid and intermittently submersed.
Then again, I'm just making an educated guess.
BTW., does your fluid look normal? If so, then it's not air getting in.
