D-17 Exhaust
eye4iron
02-26-2007 19:20:29
I have a D-17 series III that has an exhaust/intake manifold that is exhausted. The exhaust ports are very thin and burnt away. To surface the gasket flats would be useless. Is the d-17 manifold the same as the wd-45 ? I see both on ebay and I am not sure which would be correct.
Also, what is the size (diameter) and the length of the studs that hold the manifold on?
Eye4Iron
02-27-2007 19:12:17
 Re: D-17 Exhaust in reply to eye4iron, 02-26-2007 19:20:29
Kip Thanks for the info. It is very useful. Do you or anyone know where I can get the length and diameter measurments for the studs that screw into the head for the maifold?
Kip[UT]
02-27-2007 08:14:20
WD45 through D17 Series III is the same manifold. But the WC/WD manifold has a smaller throttle bore size so best to avoid those. Current new replacement manifold is the same for Styled WC through D17 III. A later D17 or 170 manifold would also work for you if you adapt to different type of muffler attachment. Kip
