WD WD45 crank
TJanak
02-26-2007 07:02:58
I have 4 WD cranks and I really would like a WD45 crank. Would it be fair to offer 2 WD cranks for one 45 crank? Or are they valued pretty evenly?
Also, can anyone recommend a source for ordering rebuild kits that is more knowledgeable and helpful with these tractors than I am?
TJanak
02-27-2007 04:52:19
 Re: WD WD45 crank in reply to TJanak, 02-26-2007 07:02:58
What is a fair price for each of these cranks?
Thanks for the help!
Kip[UT]
02-26-2007 08:14:07
The 45 cranks demand quite a bit more $ than WC or WD crank because it is a very popular upgrade to stroke these earlier 201 CID engines to 226 CID w/ the WD45 crank, creating an abundance of good used WC/WD cranks, and a decent demand for the 45 cranks.
BDT in Minnesota
02-26-2007 08:14:02
You should be able to find a new home for your WD cranks in th classified section on this site...Also mention, like you did in this post, that you are seeking a WD45 crank....Now for more good news; this site has a good selection of parts to rebuild your tractor. BDT
TJanak
02-27-2007 04:54:47
 Re: WD WD45 crank in reply to BDT in Minnesota, 02-26-2007 08:14:02
BDT in Minnesota
02-27-2007 11:06:35
 Re: WD WD45 crank in reply to TJanak, 02-27-2007 04:54:47
The price would vary upon the condition of the crank itself...A micrometer reading would help to determine if the crank has been reground, and if regrinding would be required now...If the crank is in good, useable condition,,it would understandably be worth more..As Kip stated, the WD45 crank would be worth more. WD,,,,well $100 really shouldn't be out of line for a good WD crank. If you price them too high, they probably won't sell....If they are in poor condition,,they are merely cores...
