cylinder size
lynn in IL
02-25-2007 11:04:17
I bought an AC CA a few years ago it has no lift cylinders on it. I was wandering the correct size to install and if they were availible new or rebuilt.
BDT in Minnesota
02-25-2007 11:46:12
 Re: cylinder size in reply to lynn in IL, 02-25-2007 11:04:17
Your best route will be to find a pair of original CA cylinders...The Ca has a low volume, high pressure system, which is not common on the newer hydroulic systems...The cylinders would also have to be the correct length to properly fit the linkage....And then, the cylinder ends would have to be modified to fit the linkage...
