D17 front end
tim in ky
02-24-2007 07:24:43
I have a 1959 D17 with a narrow front end can I put a wide front end on it off a nother D17? I found one off a nother D17 dont know what year?If so how much trouble is it to change?
old
02-24-2007 09:30:07
 Re: D17 front end in reply to tim in ky, 02-24-2007 07:24:43
Yep it can be done and one from one D-17 should fit right onto another D-17. You will need a way to hold the front end up safely when doing so and it will take some grunt work to swap them out but thats about it
Glen Sundberg
02-24-2007 09:49:15
 Re: D17 front end in reply to old, 02-24-2007 09:30:07
You need to watch, their were two different size bolt (the bolts you bemoved the narrow wheels)may be different, you may need to drill and tap to 5/8 because the holes on the new front end may be 5/8 .and i reinforced the wishbone on mine,the factory is flimsy.
