210 over steering
H2
02-23-2007 11:49:54
My 210 does not want to go straight and I must constantly and very slowly turn the steering wheel to the right. Is there an easy fix for this? Maybe need to rebuild the steering input hydraulics? It turns well, but just wants to wander left.
856puller
02-24-2007 07:19:25
 Re: 210 over steering in reply to H2, 02-23-2007 11:49:54
some leakage is normal but if you think it is excessive the place to start is the ram. take one hose off turn the wheel to the lock and hold there should be very little oil coming out if there is you have bad orings in the ram. the engine has to be running
EdW
02-23-2007 17:20:34
I put over 4000 hours on a 210 and it always did the same thing. Very slowly turning of the wheel is normal due to the unequal displacement of oil on each side of the steering cylinder due to the rod only on one side. Some International tractors had the rod come out both ends with only one end attached to anything. This helped. If your steering wheel turns fairly fast you may have seals leaking internally in the cylinder. Hope this helps!
