WD45 Ignition
PacificTreeFarmer
02-23-2007 09:59:52
I'm getting ready to instal electronic ignition in my WD45.
What type of plugs & wire (resistor/non resistor) will work best?
Also, will cap/rotor need to be swapped? and
Will this effect timing?
Thanks!
Steve in N.J.
02-25-2007 20:38:07
 Re: WD45 Ignition in reply to PacificTreeFarmer, 02-23-2007 09:59:52
All you'll need to do is possibly do a little timing adjustment if your still running the 6V system. Changing plugs, wires, and Ignition parts is not neccessary. We have the E.I.'s in stock if needed..
Steve@B&B
PacificTreeFarmer
02-26-2007 10:32:17
 Re: WD45 Ignition in reply to Steve in N.J., 02-25-2007 20:38:07
Thanks for the replies Guys...
The tractor was converted to 12 volt before I got it. Will this make a difference?
Also, I want to replace the plug wires anyway they are looking a little ratty...Sounds like I don't have to worry about the resistor/non-resistor issue though...
Tom Miller
02-24-2007 11:32:51
When I did mine this fall, all I had to do was adjust the timing by rotating the distributer.
