tires for a b
tim coltman
02-22-2007 18:24:01
hi ive noticed that some b's and ca's have wide tires on the back mine has the skinny ones im not near the tractor now so i cant tell you what size they are. my question is will the wider rims bolt right on it has a big cast center and i think 4 bolts 2 of them exand towards the rim to tighten it are the bigger riims like this? and would anyone be willing to trade for a set of wider ones they are in good shape about 95% tread but have some minor cracks. thanks tim
acsteve
02-24-2007 05:59:22
 Re: tires for a b in reply to tim coltman, 02-22-2007 18:24:01
Did any early b"s come with 8.3x24? I have seen some pics of early ones which seem to be realy small tires.
JMS/MN
02-23-2007 13:30:51
I think the CA came with a 10-24 tire. Regardless, the CA wheel will not interchange with the C or B. CA had the spinout rims.
steve(ill)
02-22-2007 18:34:37
i thin they used 8 inch wide and 9 inch wide rims. the CA probbly hs the bigger, the very early B has the thinner. Next you can put on tires between 8 inch wide and 13 inches wide. Most common are the 9.5 inch and 11.2 inch. I like the 9.5 personally on the B.
