'52 WD engine parts
CumminsMan
02-21-2007 15:20:53
Dropped a valve. Would anyone have a power-crater piston lying around. Would need rings and possibly the wrist pin as well. I think we can salvage the sleeve. AGCO's prices aren't too bad, but just thought I'd ask. Would also be interested in a complete head.
BDT in Minnesota
02-21-2007 17:22:27
 Re: '52 WD engine parts in reply to CumminsMan, 02-21-2007 15:20:53
You may want to measure the bore and stroke on that engine...It could have been upgraded with a 4 1/8" overbore kit.Standard bore on the WD is 4"..Also if the engine has it's original crank, the stroke will be 4"...If a WD45 crank has been installed, the stroke will be 4 1/2"...
Then to goof things up a little more, there was a choice of four different compression ratios that the WD was originally sold with..Anything that you may find in that engine would not suprise me...But knowing the bore and stroke measurements and whether the piston has a dished or flat top would help...There were also variations in rings..So take note of the number and type of rings, and their thickness.. Thought I'd drop ya a note , it is more fun when ya can git the correct part on the first shot..
