G Allis generator
Richard Turner
02-21-2007 13:35:49
I am attempting to take a 12volt G Allis back to 6 volts. I found an old generator in a barn. The owner once had a "G". The Delco-Remy numbers are 1018547 8H30. I don't have a parts catalog for the G, but if someone out there has one, would ya check the part number for me? Thanks for any help!!
soundguy
02-21-2007 19:13:18
 Re: G Allis generator in reply to Richard Turner, 02-21-2007 13:35:49
According to both my oem and I&T service manual, the G takes a 1101854 genny
A check of my g shows a DR tag with 1101854 8F 8
I supose there may also be a genny from a MHP that 'may' fit as well..
Soundguy
Bob
02-21-2007 23:14:20
 Re: G Allis generator in reply to soundguy, 02-21-2007 19:13:18
I never did come up with a match for that Delco number.
AFAIK, the MHP's used AutoLite generators.
souNdguy
02-22-2007 05:47:13
 Re: G Allis generator in reply to Bob, 02-21-2007 23:14:20
If the bracket is the same, that Al genny may fit.
The casting for the MHP block and the Allis G block is around the same N62 engine, save fro the bellhousing area, AFAIK.. that may open up another avenue for a generator for the poster..
Soundguy
Bob
02-21-2007 14:11:24
Is the generator you found the little, unusually short unit like the G's used?
I have NOT yet found what a Delco 1018547 was originally used on, but a DID find a reference that lists Delco generators # 1101851 and 1101854 as being used on the Allis "G's".
Richard Turner
02-22-2007 06:45:09
 Re: G Allis generator in reply to Bob, 02-21-2007 14:11:24
The generator is rather short. IT measures 4 1/2" in diameter, and 8" in length. 8" is from tip of pulley bolt to end cap on the rear. Also, my dad tells me he thinks generators with black tags were 6 volt and red tags were 12 volts? Ever heard this one? Thanks yall for your help!!
