battery
cmazu
02-21-2007 12:46:14
what battery should i use with a model d grader 1953 gas 226. 12v system i am having trouble cranking the engine over. need more cranking amps?
steve(ill)
02-22-2007 18:41:24
 Re: battery in reply to cmazu, 02-21-2007 12:46:14
you dont need a lot of cranking amps. a 550 amp battery will do. probably need to clean the battery and starter cables and make sure everything is tight. i would bet more on porr cables or fittings than the battery.
