adjusting the timing and points on wd45
terry palmer
02-20-2007 17:31:27
I have a 53 wd45 that recently will not start. I have gas and spark and new points and condenser. I get it to run and 2 or 3 days later I have to reset the gap through trial and error to get her to fire. I have converted it to a 12 volt sys with a reduser only the battery, alternator and snow plow run off the 12, every thing else is 6 volt Other history is she sat in a yard for 10yrs before I got it running 3yrs ago. Untill this year there was no problem with starting and running. Can I adjust the #1 cylinder to top center and adjust the distributor to just past closed? I can not at this time replace the timing chain (cold). Is there something else I have over looked or could try?
RENE'S
02-22-2007 15:44:07
 Re: adjusting the timing and points on wd45 in reply to terry palmer, 02-20-2007 17:31:27
CHECK THE DISTRIBUTER DRIVE GEARS AT BOTTOM OF SHAFT FOR PROBLEM OR IN MY CASE ONE RUSTED TOOTH SKIPING ONE TOOTH AT A TIME WILL SLOWLY RETARD THE SPARK RENE'
chalmersbob
02-20-2007 19:30:30
doesn't have a timing chain, gear driven. Bob
Terry palmer
02-20-2007 19:37:51
 Re: adjusting the timing and points on wd45 in reply to chalmersbob, 02-20-2007 19:30:30
Could the gear have skipped? And if it did whats next?
chalmersbob
02-21-2007 17:02:54
 Re: adjusting the timing and points on wd45 in reply to Terry palmer, 02-20-2007 19:37:51
probably didn't skip. if it did, then it needs to be torn down. Bob
terry palmer
02-20-2007 19:29:09
The post secures the points inside the cap. How do you provide the counter pressure? Since the post goes through the insulator could I fill it with the silicone and spin the post to ensure coverage?
terry palmer
02-20-2007 18:33:37
Both are new.
old
02-20-2007 18:50:54
 Re: adjusting the timing and points on wd45 in reply to terry palmer, 02-20-2007 18:33:37
Then you may have a problem with the insulator in the side of the distubutor. Some times they go bad and cause the same type of problem
terry palmer
02-20-2007 19:07:14
 Re: adjusting the timing and points on wd45 in reply to old, 02-20-2007 18:50:54
When I put new points on, I took everything apart and the insulator was cracked and fell apart. Hard to find part so I glued it back together and used a zip tie to keep it together before I replaced it. Thanks keep thinking I'm out of ideas
old
02-20-2007 19:16:29
 Re: adjusting the timing and points on wd45 in reply to terry palmer, 02-20-2007 19:07:14
Glueing it doesn't work often because the crack conducts electicity. What I have done was use a wire and then take silicone and fill in around the wire. Doesn't take much to loose the power in that insulator. I have a ford that had the same problem and I did the wire thing and silicone and it has run that way for 15 years now. But before that it about drove me crazy
old
02-20-2007 18:03:51
Points should be set at .025. Sounds like you may have a bad rotor or cap. Yes both do go bad and some times an engine will run one day and not the next because ot them being bad. This time of year if they are bad they can be real trouble because of the humidity
