WD Front weight hanger design.... got one?
uh oh
02-19-2007 20:55:08
im kinda tired of my wd coming off the ground on the front due to lack of weight if i have the blade or brushhog or whatever up. Has anyone got a design for a weight hanger or do they make one factory. Or is there another way to get the weight up there to offset the implement? not much fun having to steer with the brakes :-) thanks yall
JMS/MN
02-22-2007 14:53:26
 Re: WD Front weight hanger design.... got one? in reply to uh oh, 02-19-2007 20:55:08
I made a WD into a reversed loader about 30 years ago, and since then, extended the C-channel and steering sector to make room for a different front pump. When I did that, I had room in front to lay wheel weights flat on a mounting bracket using the steering sector bolts. You could do the same thing without extending the C-channel- just use some 2x2by quarter-inch channel, using the two top bolts on the front of the frame. Extend far enough forward to contain the round weights. I stacked four weights on the frame and it kept the front end (now the rear) where it should be, except on the largest of rocks- but I could still push them off the field- just couldn't lift them.
BobHnwOh
02-20-2007 03:53:29
Here is a bracket and weight for sale. third party image
old
02-19-2007 21:18:44
I think I have that also out here or something that would get you closer to that. See you didn't look around enough saturday
