AC 200 hyd problems
Nick Reed
02-18-2007 17:55:41
I am in the process of buying a 200 diesel that has some hydraulic problems. It has no steering pressure or lift pressure. I"m not sure if the pump is bad or if it has lost prime. How can I tell? How are you suppose to bleed the system out if it has lost prime? Also, does anyone know what size the supply fuel line from the tank is supposed to be? My supply line is either too small or clogged. At high rpm"s, the pump is starving and drawing air around the seals on the strainer filter. The supply line looks very small to me; maybe 1/4" OD plastic at most. Thanks for any help.
Joe(TX)
02-19-2007 05:33:13
 Re: AC 200 hyd problems in reply to Nick Reed, 02-18-2007 17:55:41
The hydraulics do not need bleeding. Not much of a way to tell the problem without tearing into it. Possible problems are clogged strainer, Loose connection of intake tube, low oil, or bad pump.
The fuel line is a 1/4 in steel line or hose. You may have trash in the tank stopping up the outlets.
