spark plugs for D14
joel heaton
02-15-2007 16:41:33
are the Ac delco r45 spark plugs a good match for a D14?
thanks Joel
joel heaton
02-16-2007 04:07:35
 Re: spark plugs for D14 in reply to joel heaton, 02-15-2007 16:41:33
Glen, the D14 is the model of the Aliis tractor I have. I think you are refeering to the D14 champion plug? see my confusion??
regards,
Joel
Glen in TX
02-15-2007 17:32:51
AC R45 is a resistor plug and Champion equivalent would be RJ8C and both those are a 14mm thread size plug. The D14 is kind of a cold plug for a gasoline engine and would be a 18mm thread size so not a match with R45. An AC equivalent for D14 is AC C86. What engine or tractor are you wanting plugs for? If you need 18mm size a better match for a gas engine is D16 or D21 or AC C88 or C88L or Denso L14U or Autolite 3116.
