Holding a ghead gasket on a D19 diesle, and other info.
Glen
09-21-1999 15:42:44
Dose any one know how to hold the head gasket on a D19 diesle. I have palaned the head, decked the block, put in new head bolts. Done all the normal things I know to do. Also dose any know what the differences are between the two pistons used with the two differnt camshafts. Dose anyone know what the piston to top of deck tolarances should be. Or where I can find this information.
Brian
09-23-1999 11:08:47
 Re: Holding a ghead gasket on a D19 diesle, and other info. in reply to Glen, 09-21-1999 15:42:44
Have you checked how high your cylinder liners protrude above the block? If they're too high or low it will leak. If this is your problem, they will have to be pulled and usually the block will need to be machined. Hope this helps. Gordon Chance, jump in here and help us out. Brian
